Richmond 4+1 girkasse
nos
Registrert: tor sep 23, 2010 17:22
Legg inn av nos » tor jul 24, 2014 11:39
Er det noen på forumet som har erfaring med denne?
How to Make
5th Gear Act Like
an Overdrive
Example:
Muncie close ratio is 2.20 1st gear (multiply by the likely rear end) x 4.56 = 10.03
Assume 27” tire, RPM @ 70 MPH = 3972
With 7021710A 5 Speed ratio is 3.28 1st gear (multiply by the likely rear end x 3.08 = 10.10
Assume 27” tire, RPM @ 70 MPH = 2683
2683/3972 = the same as a .68 overdrive!!
Now what?
1. The Richmond 5 Speed can duplicate the Muncie through first 4 gears if you choose.
Muncie Trans Rear Ratio RICHMOND Trans Rear Ratio
1st 2.20 4.56 10.03
1st 3.28 3.08 10.10
2nd 1.64 4.56 7.48
2nd 2.45 3.08 7.55
3rd 1.28 4.56 5.84
3rd 1.99 3.08 6.13
4th 1.00 4.56 4.56
4th 1.52 3.08 4.68
The Richmond 5-Speed matches a Muncie!
NOW! Shift
Nils Olav
