dekktrykksensor C6
bilmotor
Registrert: lør sep 22, 2007 21:57
dekktrykksensor C6
Legg inn av bilmotor » man nov 05, 2007 22:49
Hei.Er det noen som vet hvordan man programerer dekktrykksensorer på C6 :?:
v8power
Legg inn av v8power » tir nov 06, 2007 00:16
Du tenker på relocation programeringen?
TPM Learn Mode Description
The tire pressure monitor (TPM) system uses the remote control door lock receiver (RCDLR), body control module (BCM), keyless entry transmitter, 4 radio frequency transmitting pressure sensors, and the serial data circuit to perform the TPM learn mode functions. The sensor learn procedure must be performed after each tire rotation, RCDLR replacement, or tire pressure sensor replacement. Once the TPM learn mode has been enabled, each of the sensors unique identification (ID) codes can be learned into the RCDLR's memory. When the RCDLR receives a sensor's transmission, it sends a serial data message to the BCM to sound a horn chirp. This verifies the sensor has transmitted its ID code and the RCDLR has received and learned it. The RCDLR must learn the sensor IDs in the proper order to determine sensor location. The first learned ID is assigned to the left front location, the second to right front, the third to right rear and the fourth to left rear.
The RCDLR will cancel the TPM learn mode if more than 2 minutes have passed and no sensors have been learned, or if more than 5 minutes have passed for the entire procedure. If the learn mode is cancelled before any sensor IDs are learned, the RCDLR will remember all previously stored IDs and their locations. As soon as the RCDLR learns the first sensor ID, all previously stored IDs are erased from the RCDLR's memory.
Sensor Learn Procedure
Important: Before proceeding with the procedure below, ensure that no other learn procedure is being performed simultaneously.
1. Select the ACC position on the ignition switch.
2. Simultaneously press the keyless entry transmitter lock and unlock buttons until a horn chirp sounds, indicating the TPM learn mode has been enabled.
3. Starting with the left front tire, hold the antenna of the J-46079 against the tire sidewall close to the wheel rim at the valve stem location then press and release the Activate button and wait for a horn chirp.
4. After the horn chirp sounds, proceed as in step 3 for the next 3 sensors in the following order:
1. Right front
2. Right rear
3. Left rear
5. After the left rear sensor is learned, a double horn chirp will sound indicating all sensor IDs have been learned.
6. Select the OFF position on the ignition switch to exit the TPM learn mode.
På omtrent alle andre GM biler kan man lære posisjonene på nytt uten å bruke spesialverktøy. Burde være mulig på Vetten og. Skal lete litt mer og se om jeg finner noe.Står nok i innstruksjonsboken også hvis du har den
Sist redigert av v8power den tir nov 06, 2007 00:22, redigert 1 gang totalt.
Terje-c5r
Legg inn av Terje-c5r » tir nov 06, 2007 00:17
Hei. Eg mener fremgangsmåten er lik som på c5, her er oppskriften:
06.04.07 Tekst: Kjetil Kleppe
Programmering av dekktrykk sensor C5
Enkelte Corvetter av generasjonen C4 og alle fra generasjon C5 er levert med lufttrykk sensor i felgene. Dvs. en kan lese av lufttrykk og/ eller at bilen varsler om for høyt/lavt lufttrykk. Hvis man kjøper ny sensor må denne kodes til bilens datahjerne. Under følger en beskrivelse hvordan man utfører dette på Corvette C5:
1. Monter alle fire hjul/ dekk på bilen og dra til alle muttrer med rett moment. La bilen stå på bakken.
2. Skru på tenning til posisjon "On"
3. Trykk "Reset" knappen for å fjerne evnt. feilmeldinger.
4. Trykk på "Option" knappen flere ganger til displayet ikke viser noe.
5. Trykk og hold "Reset" knappen lenger en 10 sek. "Fob traing" viser i display..
6. Trykk på "Option" knappe igjen til "Tire Training" viser.
7. Trykk på "Reset" kanppen til melding:"LEARN L FRONT TIRE" viser.
8. Hold en magnet (eks. gammel bilhøytaler el.) over ventilen for venstre forhjul.
9. Hold manget til hornet lager lyd, først da er programmeringen klar for dette hjulet.
10.Programer de resterende 3 hjul ved å følge instruksjon i panelet i bilen. Rekkefølgen er som følger: Venstre front, høyre front, høyre bak, venstre bak.
For mer informasjon les Corvette Service Manual, side 3-114:Low Tire Pressure Sensing-TPM Sensor Programming.
Lykke til..
Kjør en Corvette og vis de andre
at DU har skjønt det.
erikmb
Legg inn av erikmb » tir nov 06, 2007 21:17
På C6 og Z06 må man ha ett programerings verktøy.Jeg måtte kjøpe det fra usa da jeg kjører mye på bane og skifter hjul ofte. Det finnes flere typer du kan bruke.
bilmotor
Legg inn av bilmotor » tor nov 08, 2007 00:13
Takker for svarene .Har funnet et verktøy :OTC 3833 på nett som jeg tror kan brukes
erikmb
Legg inn av erikmb » tor nov 08, 2007 00:53
Jepp. den er bra. den samme som Bergheim bruker.
